iluvmybike
Gosh, poor old OP only asked how to get some mucky lubes stains off their frame and it ends up in an argument about wax dlows!!!
I’m enjoying the debate…..keep going lads.Gosh, poor old OP only asked how to get some mucky lubes stains off their frame and it ends up in an argument about wax dlows!!!![]()
and lasses...I’m enjoying the debate…..keep going lads.
Seems okay if you get the wax right, but with Molten Speed Wax sitting at £20 a pack it’s just as cost effective to buy that and it’s probably the second best wax on the market.I'll give the Wax method another try, using :
PTFE Powder 50g + Refined Paraffin Wax 500g
Link to a decent priced wax melt cooker?Seems okay if you get the wax right, but with Molten Speed Wax sitting at £20 a pack it’s just as cost effective to buy that and it’s probably the second best wax on the market.
I’d guess that if giving it a go it’s safest to try a well known product as that way you know you haven’t made any mistakes so if it doesn’t work out it’s definitely not that. It sounds like you know what you’re doing though in picking the right base wax, so maybe you’re all good!
Search crockpot slow cooker on Amazon. 1.8L is fine. Should cost about £15Link to a decent priced wax melt cooker?
Yeah that’s the same one. It’s the one I haveI was thinking about getting this slow cooker from Argos 1.8 Litres for £15. (Looks similar to the Amazon item.)
https://www.argos.co.uk/product/9306561?clickSR=slp:term:crock pot slow cooker:1:24:1
I've ordered the PTFE Powder 50g + Refined Paraffin Wax 500g from £16.75
https://www.ebay.co.uk/itm/325089309670
One other thing is to make sure you do it on a new chain. Then prep the hell out of that chain with white spirit in shaker bottles, and then rinse through with a couple of shakes in isopropyl alcohol.I was thinking about getting this slow cooker from Argos 1.8 Litres for £15. (Looks similar to the Amazon item.)
I'll take the bike (and chain) out on a ride tomorrow.
- I soaked the new chain in white spirit multiple times and left it soaking for a few days, then rinsed it in meths and wiped it clean.
- Melted the 500g wax in the new slow cooker and added the 50g PTFE powder. (Took over an hour to melt.)
- Stirred the mixture, put the new chain in the pot on a wire and swished it about.
- Left it for 1/4 hour and swished the chain about again.
- Took the chain out of the pot, shook the excess wax off, left the chain to dry
- Fitted the chain while it was a bit stiff with wax, because I wanted to keep as much wax on the chain as possible to avoid rust.)
I've used the wax method before, but used just candle wax and a bit of oil.
See my post from 2016:
https://www.cyclechat.net/threads/t...-chain-oil-and-bike-lube.203374/#post-4355699
Have you actually started using the melted wax method yet, as about a month ago you were just considering it and regurgitating the stuff you'd read on the internet.yeah this looks great. The only difference for me is not shaking off the excess wax (same reason as you said with wanting to keep as much in as possible), but I think it's a minor detail. Looks great.
You should see very different results as to with candle wax and oil.
You might say that he’d been waxing lyrical about it…Have you actually started using the melted wax method yet, as about a month ago you were just considering it and regurgitating the stuff you'd read on the internet.
Regurgitating stuff read off the internet is a bit nonsense. "quoting science" is probably more apt.Have you actually started using the melted wax method yet, as about a month ago you were just considering it and regurgitating the stuff you'd read on the internet.
So that would be every other commute then? This is Manchester commuting, bike and rider can arrive home dripping wet and covered in road grime (despite mudguards which strangely offer no protection from the water that falls out of the sky). I think on top of a 12hr shift that equates to a 14+hr day including the commute it would be somewhat a faff to be swapping chains every few days, not to mention the cost of continually powering the crock pot.Just means you only have to full immerse after wet rides
