nlmkiii
I'm a bit obsessive about drive train cleanliness and efficiency, but I'm going to try and recommend something much more reasonable for the every day rider! I wouldn't suggest going out waxing until you get a similar level of obsession... but... there are some really good drip lubes out there that could offer a better solution than what you are currently doing.Just to follow on from this
I purchased some muc off dry lube as I tend to really only go out when it’s dry and also wanted to see if it kept my chain cleaner.
I’ve been cleaning and re lubing the chain after every ride, it’s been a couple weeks since I’ve been out as weather up here has been horrendous, I went out yesterday however after around 15 miles I could hear the chain was very dry?
I’m guessing the dry lube had dried up in the time since I lubed and going out yesterday?
Have read a few reviews saying it doesn’t last well at all?
Highly recommend switching to Squirt lube, or Silca Secret Chain Lube! If you use a good lube and ensure it penetrates well with an effective application then you won't have as much dirt ingress, as it physically won't be able to get in to cause problems. As others have said, once lubed make sure you clean the excess lube off the outside of the chain too. It doesn't add any lubricating benefits, and just attracts dirt which can then ingress in to where it really matters.
Also just to be anal, make sure you're cleaning your chain effectively. You don't have to give it a deep clean after every ride though, just a quick wipe down. But taking it off and cleaning it using the shaker bottle method every now and then is a very good idea.
Why Squirt / Silca Secret Chain Lube?
Squirt lube is the most commonly recommended (Olly Bridgewood even recommended it on GCN after he was no longer allowed to recommend it on GCN because of sponsorship issues!). It's also relatively cheap compared to other good lubes. Spend longer applying it than other lubes though,
Silca Secret Chain lube is better because of the titanium disulphide additive, but you'll be fine with both.
You can go super expensive with lubes, and they are better (and some like Synergetic by Silca are more about ease of application than being better), but perhaps not necessary right now
