Beebo
Firm and Fruity
- Hexleybeef
100.6kg today. Not very good but I did fall off the wagon after a big hangover. Still a loss is a loss.100.9kg today.
4.2kg lost since new year.
Target is 90kg by June, very doable.
Eight pounds this year already is very good going.2lb off since last week.
Happy with this nice slow steady progress, 8lb so far for 2018.
Another *mumble mumble* stone to get off before resuming my cycling career![]()
Excellent progress ... At this rate you should be free to join us for some or all of my Cheshire forum ride on June 2nd!2lb off since last week.
Alcohol is one of the biggest curses of those trying to lose weight, and I'm trying to cut it out completely for as long as I can - I've not touched a drop so far this year.Had a great start to Jan losing 6lbs to only go and gain 4 again!! Work pressures meant more drinking which meant more eating and making excuses.
Feb has come around and continued bad habits, however back on the bike and done 1 spinning class this week with another tomorrow morning as well as signing up for a 12 week weight loss program at a local gym. Fingers crossed the weight program is what I need to kick start shifting the excess weight plus as the mornings get lighter and warmer I plan on getting on the bike at least 3/4 mornings per week.
99.6kg today. Slow and steady weight loss is doing the trick. Hope I can keep the motivation up.100.6kg today. Not very good but I did fall off the wagon after a big hangover. Still a loss is a loss.
I find the motivation to lose excess weight isn't the real problem ... The real problem is getting complacent once the target has been achieved!99.6kg today. Slow and steady weight loss is doing the trick. Hope I can keep the motivation up.
I have two problems with setting weight loss targets. One is that my motivation for achieving an arbitrary figure can wane quite easily, and the other is the same as yours in that if I do achieve a target, I then forget about it and my weight goes back up again.I find the motivation to lose excess weight isn't the real problem ... The real problem is getting complacent once the target has been achieved!
I got down to just over 77 kg (~12 stone) but then relaxed and before I knew it I was back up to 89 kg (~14 stone).
I suspect the secret is to slowly drift down the last kg/lbs so it doesn't take a big change in habits to stabilise at the target weight. After that, set a sensible margin either side of that weight, say +/- 2 kg (3 lbs). If you approach the bottom limit, allow yourself a few extra treats until you are back to the target. If you approach the upper limit, switch back to your steady weight-loss regime until the surplus has gone.
