Cush
- North Cumbria but still a Geordie
I am not sure to be honest but I suspect it is a bit more than that.Is the sauna bit just loss of fluid?
Why haven’t I lost weight after exercising? You asked Google – here’s the answer
http://www.theguardian.com/commenti...-not-lost-weight-exercise-google-autocomplete
This may be of interest.
The problem is the way Calories are calculated. Recently a TV doctor (can't remember what program) on a calorie controlled diet replaced 400 calories per day across all food stuffs with 400 calories of raw nuts, and his weight dropped off, as it is not possible for the digestive system to break down the fats and proteins in nuts efficiently.No, it isn't that simple. It is simple, but not in that way.
If you want to limit yourself to one particular category of food to reduce, then that's your choice, but the simple rule of weight loss is that CI<CO (calories in should be less than calories out), and what those calories are made up of is unimportant in terms of weight loss. Your body doesn't think "ah, carbs........let's store that for later as fat. Right, here is some fat, let's burn that straight away". It's straight-forward 2nd law of thermodynamics......burn more fuel than you put in, and you'll start using your reserves. Both fuel and energy expenditure are measured in the same terms (kilo-calories), so you just have to make sure that over the course of say a week you burn more fuel than you consume. Whichever way you cut it, whichever areas you reduce, this is the underlying straightforward truth of any successful campaign to lose weight (and of course, the reverse is behind almost every weight gain).
A weigh in this morning had me down to 68.8kg. That's 9.2kg lost since the start of the year. (20.3lbs).
My target is 63kg ideally. That is what I was even my back went on me. My max is 65kg and if I could really make it 60kg would be my preferred option. So ideally another 6kg to go and if possible another 9kg. At least I'm over half way.![]()
Steadily moved down to 81.7kg last Thursday, but by the end of the weekend back up to 84.6!![]()
The next few weeks are going to be challenging though because of us leaving the UK in 5 days time to go and live in a country I know very little about and have never visited, but that's part of the fun!
What's their food like? Is it tempting?
