I'm not taking issue or seeking to argue with your intent, I'm sorry if that's your perception. I'll let you know if the new one dies within 5 as you predict.sorry but I'm really not buying your advice. I reckon in five years time, I'll post another thread about how to keep this machine going... meanwhile, you'll be replacing your new washer.
Yep, that was my earlier advice to MV.Not read the entire thread, but there is often an inspection hatch on the front.
Drain and remove and clean the filter.
Get on the floor with a torch, and with a crochet hook or stiff piece of wire, try to flick the impeller blades to check if jammed.
Our tame engineer reckoned they and Siemens are more reliable, along with Miele. (Although the latter control spares, so when it breaks you need an engineer - and there are no Indys hereabouts due presumably to our close proximity to Miele's UK H.O., which si a bit naughty, we thought)Ask the questions on the forum below, they will advise you. I kept a Whirpool piece of crap going for 16 years using that. Re-soldering dry solder joints etc. The last washing machine I got some cheap crap out of Currys just failed with its drum bearings. These could be replaced unlike most modern sealed drum machines, but the utter piece of sh1t was impossible to work on., unlike my old Whirlpool that you could take the front off. I just replaced it with a more expensive Bosch. Hope it's worth the extra money. German cars haven't impressed me for the premium they demand. Hopefully the washing machines fair better..
https://www.ukwhitegoods.co.uk/forums/
If there's nothing round the impeller,take the pipe off the back of the pump and feel inside the pump inlet pipe,you may find a 10p piece,they are the perfect size to wedge in the pipe,when the coin is at 90 degrees to the pipe it blocks the pipe, it can swivel in the pipe and the pump will be working fine again,I found hundreds over the years when I fixed washers for a living.
I've had the pump off but couldn't remove the cover to the spinning thing due to those bloody torx screws... but i could have a good look in both orifices and could get my finger in (calling @Fnaar) and it appears to be clear. The sump on the rubber pipe leading the the pump was also free of any gunk, but did have a pound coin in... result!
I'll try to remember this next time I drag the machine out. Thanks.I can't believe nobody has mentioned the number one, most common reason why washing machines fail to pump out properly.... simply that somebody has shoved the corrugated waste pipe too far down the upright plastic pipe at the wall, partially blocking it. It's so common that washing machines come with a plastic 180 degree bend thingy attached to the waste.
There is a water level sensor on the back of the drum, which gets clogged with scum and stops the programme from working. Pull it off, clean it out then check it by sucking or blowing and listening for the click from the little switch chamber.
Our first had 5+5 years on it, the latter half a special sales incentive, and our second 5 years, so I guess we could have topped that one up to 10, but it was good as gold for 12 years!We've got the Miele service contract on ours.
Miele used to make bicycles you know.
Our old washing machine died due to the bearings in the sealed drum (what a stupid design!).
"New" one is on it's 3rd set of motor brushes..
