gbb
- Peterborough
I suspect not, the force of the water being pumped would simply push the airlock(if it existed) before it.Can you get airlocks in washing machines?
Programmer issue maybe ? Not easy to check, but it may be an intermittent output from the programmer, older ones used to use micro switches which can ultimately fail/play up.
Pump first though, you'll need some strong pliers and a healthy dose of patience perhaps to get the clips off, they can be difficult to access.
There may well be a filter as well, check that.
