punkypossum said:
Well, after a couple of rounds of the college car park on frustruck's road bike (Thanks again for that!
) I have learnt that a) his bike (58 I think) is way too long for me B) the tiniest stone feels like you hit a a rock c) the position didn't feel as upside down as I had expected d) The bike felt twitchy as I had expected e) My lower arms started hurting immediately, f) the brakes on a roadbike don't appear to have much actual stopping power at all (especially compared to the effort put into braking), i.e. downhills should be avoided at all cost. Why create something very fast with suicide brakes?
g) although very brief and uncomfortable, it was sort of fun in a warped way
Hi PP.
Here's my contribution...
(a) I'm 6' 1.5" and I ride a 58 cm frame but my height mainly comes from my torso. My leg measurement is only about 33". Women tend to have longer legs and shorter torsos than men of the same height so I'm not surprised that you found a 58cm frame a stretch.
(B) Skinny tyres do feel a bit harsh compared to the comfort of big knobblies on a bike with suspension forks but I think a lot of people have their road tyre pressures a bit on the high side. You can make a big improvement in comfort by lowering the pressures slightly. There have been lots of discussions on this subject and some people will tell you that you need to run 23c tyres at well over 100 psi to avoid pinch punctures (snakebites). I run my tyres at about 80 psi front and 90 psi back (because there is more weight on the back of the bike) and I don't suffer from that problem. I just watch where I'm riding and unweight the bike (get out of the saddle) over rough surfaces. It may be possible to run bigger (more comfortable) tyres if your frame and forks have clearance for them. Touring bikes can usually take much more than 23c. My Basso can take 25c and that is my usual choice. My Cannondale doesn't really have clearance for anything bigger than 23c.
(c) I try to get the position on all my bikes (including my MTB) as close as possible.
(d) I wouldn't say that my road bikes are 'twitchy' exactly, but they are definitely easier to throw about than my MTB. That's partly because they are about 8-10 lbs lighter. You get used to it.
(e) Your arms probably got sore because your position wasn't right and was putting too much weight on them. A proper bike fit should sort that out. Paul Hewitt is very good for that.
(f) You do need to use a little bit more effort to apply road brakes, but you shouldn't need to be a gorilla! On anything upto about 20% downhills I use 1 or 2 fingers per lever. Above 20% I need to use 3 fingers but still manage to slow down okay. If you can lock the wheels without too much trouble (which is easily possible with modern brakes), you don't need more than that. It may be that you have short fingers in which case you need levers set closer to the bars so that you can get a good grip on them.
Some people have their brakes setup too 'tight' which makes braking difficult. If the blocks are set too close to the rims, you have to use too much strength - they go from off to full on in a couple of mms of lever travel. If you set the blocks further away from the rims so that you pull the levers further, you get much more control over your braking and don't need to pull so hard.
NB you must make sure that the levers never touch the bars under full braking, for obvious reasons
(g) MTB riding is great. Road riding is great. I ride my MTB on the road between bridleways and it feels like a slug. I ride my road bike on the odd bit of rough stuff and have to be very careful where I'd just blast away on the MTB. That's why I have several bikes - right 'tools for the job' and all that!
PS You could always come along on my Bowland ride and just do Longridge Fell and Beacon Fell - I know that you've done them before
Oh, and I use a triple chainset on the Basso for riding big hills. It has 52/39/30 chainrings and a 14-28 cassette. It's old 9-speed Campagnolo. 10-speed Campagnolo would give you the option of a 13-29 cassette. A 30/29 bottom gear isn't anywhere near as low as the bottom gear on an MTB but it is very low on a road bike and when you are fit, you should be able to climb anything on that and usually not even need the bottom few gears. I'm not sure what options you'd have with Shimano - you'd probably be able to go even lower using a MTB cassette but unless you were touring with heavy loads, I don't think you'd need to.
