Good luck. Bon voyage.
Gave myself about an hour in Oxford for old time's sake.Good luck. Bon voyage.
Been offline for a few weeks. Had a tile tagging failure a couple of weeks back, when I hit a spot with no network coverage
This is what greeted me on the northbound track in the screen shot of the map below. I could have got round it, but there was a security camera.
So I took a detour on a path, along the woods (the path through the woods has this sign):
Didn't fancy being shot so ended up cycling down this path on 25 mm tyres:
But as you can see from the map, I then hit the same track and there were more video cameras. So going to try an approach from the north
Think I have figured out a way to get the tile by accessing the path along Spittle Brook...
It looks like you can approach it from the north a long a bridleway between Alcester Heath and the A41 (purple line, below), it'll take you just into the north west corner of the tile. If you want to make sure of bagging it you could also go along the footpath to the woods and Alcester for a bit.
