Using a Brompton as a home exercise bike
u_i
Ăśber Member
Michigan
Looks like a Thai company. They presumably used the Brompton there because it was the easiest to bring along to some demonstration.
ukoldschool
The Kurt Kinetic seems the easiest and best value. The right hand clamp has a slot for the hub index chain:
494221
Vid here for info:
View: https://www.youtube.com/watch?v=goLf3zoNFEM
One cheap here if you are close to collect, then buy the adapter from evans all dont for ÂŁ75ish:
https://www.ebay.co.uk/itm/Indoor-bike-TRAINER-BY-KURT-KINETIC-ROCK-AND-ROLL-Turbo-Trainer/184048723532?hash=item2ada28a64c:g:jIMAAOSwqr5dz~N4&LH_ItemCondition=4
https://www.ebay.co.uk/itm/Kinetic-...-Models-Indoor-Cycling-Trainers-/123634017965
Fab Foodie
Kirton, Devon.
Vid here for info:
I stand corrected!
Kell
That front stand looks better than mine too.
When I use the prop that came with it it feels like I'm going downhill. I've had to prop it up on some old bricks I found in our garden.
S
snazpizaz
London UK
thanks everyone. I agree the Kinetic seems like the most reliable way to go. My only reservation is it's a tad bulky and you have to screw the brommie in and out each time you use it as an exercise bike. That said i've read that the 3 speed hub wont inhibits the Kinetic's axle clamp.
A quick return to the subject of rollers - has anyone identified a source for these:
View: https://www.youtube.com/watch?v=D_ehng4mEYs
thanks everyone sp
Kell
Rollers are rollers - any set should work with a Brompton, providing you can adjust them fore and aft. If you look at the screen grab pic you've included above, you can see that the front roller has multiple holes so that you can position them for bikes of different lengths.
Every set of rollers I've seen has a similar set up.
All turbo trainers require you to screw the rear axle into place. It's not a difficult process, but it does take a few minutes.
Thomas vr
Could you use one of the Wahoo direct drive trainers? I have their wheel on Snap which can accommodate most wheels down to a 24” wheel. (I think!!!!!) Worth contacting them. They are very helpful.
Hi Heltor,
Did you do any more research or find info of people trying to fit a brompton to a wahoo (or different brand) direct drive trainer?
I know the company says it can only fit tyre sizes up from 24 inch.
But would love to hear if people still tried and succedded.
With regards,
Thomas
I can ride my Brompton on my treadmill - but as has been said a hack bike fixed to a turbo would be the easiest option.
