Like ive ever seen you walk...notThat’s called time to get off and walk. Having a couple of spare gears at the start may delay that moment
I think my shoes may have a carbon sole.@Joffey
Could you sell the merits and advantages of speed plays in comparison to shimano SpDs
I was toying with swapping out the spd for speedplay but it can work out a costly habit trying out different pedals ( last holiday abroad I thought I could hire speedplays to try..but the hire place did not have them )
I have spd as they are seen as the go to pedals from shimano
I had shimamo on my mtb as a go to clip them went to crank brothers which were far better to me
Have you used spd to give a good comparison with speedpkay
Thanks
PS if the OP thinks about getting carbon soles ...you will never be able to clip in on a hill with them as the sole is like glass and the metal of the pedal just will not let you spin the pedals even once unclipped to get going then clip in again
A grippy rubber sole may allow this ?
What's the difference between speed play pedals and SPD-SL pedals?I've never used SPD but I have used shimano and look road bike style pedals. I'm a heavy chap and found that I was breaking the bearings on the shimano and look pedals. I opted for speedplays and they have been much better. The pedals are easily serviceable as are the cleats.
They are expensive but you don't have to buy replacement cleats.
I have 2 sets - one on each bike and I'll be honest, I'll never go back!
Is the speed of a trike anything like a road bike?I had this problem, I solved it by buying a trike![]()
Never had a drama with clipless pedals. I do still bear the scars of a crash when my foot slipped off a flat pedal.I must be missing out on loads of fun and drama by riding on flat pedals....![]()
Completely different pedals. Why ask the question when it would be quicker to Google pictures of them both ?What's the difference between speed play pedals and SPD-SL pedals?
I assume the OP has done that and is simply asking for user advice?Completely different pedals. Why ask the question when it would be quicker to Google pictures of them both ?
I looked at pictures, I don't understand how the speed play pedals are meant to work, what's their advantage?Completely different pedals. Why ask the question when it would be quicker to Google pictures of them both ?
Yes you can clip in but learn to pedal one clip foot and other un clipped and get a tiny bit of momentum will make it easier.I was going up a very steep hill, I wanted to continue going but I was finding it very hard to breathe, I barely managed to unclip. I walked my bike up the hill afterwards. Is it possible to clip in whilst being on a very steep hill or is this an accident waiting to happen? Whilst climbing a steep hill should I be in the lowest possible gear (but have a longer time doing the climb or slightly higher gear and climb at a faster speed) ? In which scenario would I manage best to do the climb?
I would be somewhat cautious about investing in Speedplay at presentSpeedplay better for longer rides or racing.
Wise choice I got cramp half way up a steep climb and when I tried to restart i fell as i couldn't get enough speed to get both feet inMake it easier by setting the release tensions on your pedals to minimum, and if you think you are not going to get to the summit, then do a controlled unclipping rather than struggling on and being forced to do it in a panic a couple of seconds later.
It is dodgy unless you do it sensibly... I look for a driveway, side road, farm track, passing place, (whatever) to start from safely, and then turn up the hill. If no such thing is available then I try to hang onto a wall or fence while I clip in.
If you can't make it up the hill in a higher gear - yes. If you can - it's up to you - try the alternatives and see which you prefer.
I did an emergency dismount on this 25% ramp. I didn't even attempt to get started again - I walked up to the bend and started off on the easier slopes higher up!
