Deleted User
- Wolverhampton
I don't think it's the pedals that's causing the drama.I must be missing out on loads of fun and drama by riding on flat pedals....![]()
Yes, it is possible to clip in on steep hills but it requires concentration and coordination. I've remounted on Hard Knott after I wobbled too close to the gravel edge and thought I was going down.I was going up a very steep hill, I wanted to continue going but I was finding it very hard to breathe, I barely managed to unclip. I walked my bike up the hill afterwards. Is it possible to clip in whilst being on a very steep hill or is this an accident waiting to happen? Whilst climbing a steep hill should I be in the lowest possible gear (but have a longer time doing the climb or slightly higher gear and climb at a faster speed) ? In which scenario would I manage best to do the climb?
Ahh, that's it. Pedal spanner anyone?Flat pedals only work on the flat.
@Joffey
Could you sell the merits and advantages of speed plays in comparison to shimano SpDs
I was toying with swapping out the spd for speedplay but it can work out a costly habit trying out different pedals ( last holiday abroad I thought I could hire speedplays to try..but the hire place did not have them )
I have spd as they are seen as the go to pedals from shimano
I had shimamo on my mtb as a go to clip them went to crank brothers which were far better to me
Have you used spd to give a good comparison with speedpkay
Thanks
PS if the OP thinks about getting carbon soles ...you will never be able to clip in on a hill with them as the sole is like glass and the metal of the pedal just will not let you spin the pedals even once unclipped to get going then clip in again
A grippy rubber sole may allow this ?
That’s called time to get off and walk. Having a couple of spare gears at the start may delay that momentBut what do you do when you need them? You won't have a spare any more ...
It isn't so much that I don't use my bottom gear at gradients below 10%, as me ALWAYS using it at gradients >= 10% unless the ramps are short enough for me to sprint up in a higher gear!Same here. Except my threshold is lower [than 10%]. And my bottom gear is a bit higher.
