Angelfishsolo
A Velocipedian
- Cwmbach, South Wales
Yes, from the middle to the bottom works.
Try adjusting the H limit screw slightly. I am wondering if the chain is going slightly too far up the cassette.
I've tweaked the H limit scree a bit. Doesn't seem to make a difference. I've adjusted the B screw a bit too and seems to have solved the problem. I've taken the bike for a spin and was working fine but then towards the end of the ride I heard these weird noises when I changed to the bigger sprockets. But now it's dark and don't know what the problem might be... Will have a look again tomorrow.![]()
I narrowed the causes down to too much cable friction and a mangled end cap. I re-greased cable and replaced the cap and the problem was solved. Runs smoothly now. Thanks everyone!![]()
