chrisb1357
Cheers for the Info
Chris
Chris
The big pro is a narrower tyre will roll better and hence is faster/ easier but a narrower tyre may also give a slightly more harsh ride. Personally I'd opt for speed/ ease.chrisb1357 said:If i was to go a little bit narrower on the tyre is there any pro's and con;s to this
Chris
Your tyre should say some like 700x35 or 700x28, etc you'll be wanting a tube which is of that diameter (700) and has a width range that that fall into (i.e for 28 a 25-32 wine tube), say a 700x23-32. Your Lbs will sort you out.chrisb1357 said:Do a pick a new tube for the bike to match tyre size or wheel size
Chris
Yip, theyll be fine 700mm diameter and they range between 28 and 45mm wide and you need 35 :-)chrisb1357 said:Well i have decided to purchase a good track pump ready for the tyres as i only have a hand pump at the minute.
For the time being until i have saved up for the new tyres i am going to buy some new tubes incase i get anymore punctures and wanted to know what to get for my current tyres which are 700x35mm
Are these ok to get for the Giant CSR4 http://cgi.ebay.co.uk/SCHWALBE-Two-...sure_cycling_bikeparts_SR?hash=item3efdac7ed2
sheldon explains more, I'll try and find the link but IIRC its the true internal wheel diameter, 622mmchrisb1357 said:Cheers,
what does the C stand for on that listing do you know. I thought it was Temp LOLOL
Chris
But they are presta valves,is this what you have now? You could get some from your lbs for a similar price if you discount the postage and you'll be sure they're the right ones.HLaB said:Yip, theyll be fine 700mm diameter and they range between 28 and 45mm wide and you need 35 :-)
They are presta as are most if not all road bikes.chrisb1357 said:At the min the ones that came with the bike have a long valve which i have to unscrew something on them to pump up.
Chris
