Thanks, I've now done that!!!The easy solution would be to see if the 38mm tyre will clear the frame when fitted on the front, and if it does, then use it on the front and put the existing front tyre on the back until it wears out then next time fit a 35mm one on the back. That way you don't need to mess around returning items to the supplier.
The guy at Halfords gave me this, clearly wrong, they're so useless!!!
It will be fine. In fact you'll probably find them easier to fit because they're a bit undersized. I agree with Skippy: they are no more likely to puncture (and just as likely for the sealant to work).The guy at Halfords gave me this, clearly wrong, they're so useless!!!
