MALT
I have a road bike with skinny tyres and I also have an excellent frame mounted pump. The pump has no gauge though. Is it possible to over inflate the tyres using such a hand pump?
The reason I ask is that I recently suffered a puncture without any intrusion into the tyre, on a tube that was two days old, the rim tape is in excellent condition with no sharp bits poking through. I never use tyre levers to fit a tyre, so it is unlikely that I nipped the tube while fitting it. There is nothing poking through the tyre, and the only damage (a pinhole) is on the inner circumference of the tube.
The tyre was rock hard after using the bike for a couple of miles (to and from the barbers) as I checked it by flicking both tyres and they both gave a "bing" in reply after the ride. Two hours, outside in the sunshine (it was a couple of weeks ago), later and the rear tyre was totally flat.
The incident left me lacking confidence in cycling, although I have ridden the bike to work and back (12miles total) a few times since without any repetition of the problem.
Are there any rules of thumb regarding getting the tyre pressure right without a gauge?
TIA
TIA
