billy1561
BB wrecker
- North west England
Good advice from jd. The reason I have mine so high is because I'm 115 kg and that's the max pressure on the sidewall.
sometimes harder is not always best - harder tires can sometimes roll slower on rougher roadsI'm now down to 83Kg but still run my Conti Ultra Sports at the max 116psi. I've always run my tyres at the max if I have a pressure gauge. If not I run them at chuffin' hard.
.... look at the Continental website, the recommended pressure for these is something like 83psi. Max pressure and recommended pressure are not the same thing ....
Some folk need to be more rigorous but I top up the road bike maybe once per week (I don't have a set routine) and if the roads look dodgy (which they have been upto 3wks ago) I don't bother topping up. On the town bike, the schrader valves seem better at keeping the air in (maybe because there was less pressure in the first placeon a side note how often do you guys check/top up your pressures? i try and check mine every wed after commute( i commute 5 days a week 40miles a day) do any of you regularly flatten and re inflate?
