Doyleyburger
- NCE West Wales
I have recently tilted my seat downwards ever so slightly. I cannot believe the difference it made. Especially with certain areas going numb. Much more comfortable
Agree to disagree there @Dusty Bin. If it makes it more comfortable for me then it most definitely the right saddleIf your saddle needs tilting nose down or nose up in order to be comfortable, then you have the wrong saddle.
I had it level for a long while. Only tilted down a little to experiment really. Definitely will not be going back,..... just takes the pressure off that area enough to make the ride more comfy.I'm running Vittoria rubino pro's done about 2500 MLS and still going strong . Seat level but I think that's a personal thing you've just got to play around with .
Iv had trouble with my knees for the last few rides. That was until I tilted my seat. In any case , the tilt was literally 10mm or so....hardly drastic !!!The correct saddle will not need tilting - that's the point I'm making. In any case, a downward tilt will put more pressure on your knees.
If you can't get comfortable on a normal setup, then all you are doing is transferring the problems elsewhere.
Yeah just looked at them. Look tidy. What they like ?I'm pushing a carrera tdf like yours with rubbino pro's on yellow side walls looks neat .
good grip had no problems with punctures up to now ( might be tempting fate having said that ) Shwalbe do one with yellow walls to and they have a Kevlar puncture protective layer but can't say how good they are .Yeah just looked at them. Look tidy. What they like ?
As you know, round here there is not many roads to go all out aggressive and quick, so comfort is the order of the day.
Well now, that's a bit of a sweeping statement, for most saddles you are correct but not for all, I know of 2 without having to think too hard about it that recommend a tilt, one up and one down.The correct saddle will not need tilting - that's the point I'm making. In any case, a downward tilt will put more pressure on your knees.
