oh yes, just returned from a swift ten miler and its amazing how well the rear mech is operating. i only moved the rear hanger around 3 to 4 mm. what is apparent is the difference in sounds the chain now makes. gone is the fast clicky humming and in is the near silence of most cogs. the chain makes a louder sound the lower the gear (larger cog) i enter. but on the ride the gears didnt jump once, i didnt need to adjust the cable tension, the gears shifted fast and for the first time on this bike i got to feel confident when ramming down hard on the pedals. im impressed by the sora considering its been battered a bit.
still, ive arrived at the juncture of, if i was super extra double picky id set the indexing up again and checkout the sounds, at which point ill purchase a new hanger and witness the best country. once the hanger had been adjusted the gears were very easy to index and were completed within 15 minutes.
one crucial tip i learnt today was, after setting the first limit screw, the one that does the adjustments for the small sized cog on the cassette, shift the gear into the 2nd smallest gear with your thumb turning the pedal slowish, then adjust and tighten up the cable, then do the other limit screw, this time the one that stops the mech from entering into the spokes. the tip feels like it iced the cake )
another crucial tip was spend £15 on some half decent screwdrivers. i began the job with rubbish id lying around.
another crucial tip was to rope in the cyclechat buddies to guide one through the thicket. many thanks everyone. have a lovely evening. mark.
great indexing vid,
View: https://www.youtube.com/watch?v=On57Tl9qYRM
