Brad123
Hmm So how come it felt so much harder. I feel comfortable at 95 rpm could that be why it was harder20-21 mph at 100 rpm is no different to 20-21 mph @ 85 rpm in power terms.
OK wont look at cadence any more just peddle (pedal thanks Dusty) hard.Like I said before - I would just ignore cadence altogether, as it sounds like this is all getting very confusing and it really shouldn't be. It's the intensity of the effort level you are training, not the speed of the pedals.
Some interesting responses here. I'll put this session into context. It is base pace, designed to prepare my aerobic base. The intervals vary in length from 10-15 minutes over three weeks. The recovery is always 3 minutes. EFR have suggested that this should be done at around 171w which equates to around 18 mph according to my turbo's power curve. I've done the longer intervals at around 17.5 mph which is very much at tempo/base pace. Putting a HRM on proved very interesting and somewhat confusing as none of the intervals strayed out of Level 2. Fwiw I'm mid-fifties, max HR around 165bpm, max HR in intervals was 135bpm around 75% of maximum. I am using these sessions to compensate for not going out on the road as a 'lone wolf'' during the winter months, so for the time being it is my long ride. The next block which I will start next week will involve 10 minute tempo/threshold sessions until mid Jan with decreasing recovery intervals starting at 4 minute down to 2 minutes now I have got the aerobic base in place. Will be interesting to see where this takes me. All comments are most welcome on this and tbh I don't take offence easily. I am quite aware of place in the pantheon of cycling. My main initial aim is to stop the steady bleed of speed in the latter quarter of rides which seems to take effect on false flat/ head wind sections. OPn mst of my favoured routes I am always heading W/SW so am frequently fighting against the wind whatever the strength.Between 15 minute intervals I would recover for 5-8 minutes.
Have just been looking on CycleOps site. Found a chart on power curve for the fluid turbo. looking at the chart it says at 20 mph(for eg) it about 260 watts. could I use the chart to get a rough idea on how hard I have work out if I hold a speed for ten 10 minute.
Or I just mad and just keep pedal.
http://www.cycleops.cz/files/trainers.pdf This is what I was looking at.I have not looked at the power curve. If you link it, I can probably check it against my power meter data given that I use a Cyclops Fluid2 trainer.
