Still tennis balls or gone for inflatable bladders?
What are you using as the main board? I am in the process of setting up a pain cave. Due to the fact that it will be on t&g floor boards in an upstairs room I am looking at trying to put together a fairly good sound/vibration deadening set up.
@CXRAndy this look s a great design mate and I think im up for the challenge of making one myself? if you don't mind sharing of course where did you get the pivot point bearings from? is this the model you have the climb on?
what are your thoughts on, do you think it would be thick enough??https://www.envirobuild.com/product...MIivqj69OP3gIVQ7DtCh2A1wKHEAQYAiABEgJubfD_BwE
Thanks @CXRAndy much appreciated,This is the company I bought them from https://www.bearingboys.co.uk/Pillow-Blocks/UCP204-Medway-20mm-Pillow-Block-Bearing-1778-p
Yes I have my climb on this rocker you see
I would go for the 18mm, but at a push 12mm https://www.envirobuild.com/collections/protective-waterproof-boards
I can stand on my 18mm plywood and it doesn't feel like its flexing under my, ahem weight![]()
Thanks @CXRAndy much appreciated,![]()
superstar cheersI added a few comments above too
I am thinking of building a board using a line of engine or gearbox mounts for the pivot and to provide some dampening. I looked on the Facebook group, but has anyone here done it?
