Binka
- Lincoln, uk
Thanks, think I will carry them...makes sense to me as it seems like an easier repair than putting a tube in.
As did mine until last winter. I have to say fitting a worm was a breeze and certainly quicker than changing a tube. There is a lot of trepidation around tubeless but unnecessarily in my opinion.Hopefully you won't need them if the sealant does its job, they are just for the bigger holes that won't seal, mine remains unused after several years.
I've aldso seen a few recommendations to carry some flexible superglue which can be used to seal cutsGuy at the LBS is wrong, I carry a few plugs and fitting tool as do lots of people.
They are the std Giant tyres that came on my wife's Liv. Not sure I can pursuade her to spend more at the moment, I'll see how she gets on for now. I've not run tubeless at all so no idea what to suggest for her. The Pro X guard sound ideal for her though, cheers 👍 (just checked & there's no stock of either IRC tyres at present )@Soltydog What tyres are you using? It is possible they are porous.
I have been using them since I started with tubeless. Plenty of grip, no punctures. Maybe 3 or 4 years use, 4000 miles perhaps. the rear started to show signs of wear so I've just put on a new set. I'll keep the less worn front as a spare.@Soltydog What tyres are you using? It is possible they are porous.
My experience is similar to PaulSB, insofar as I tend to need to put a little air in every few days. Less than latex tubes mind you, which I used to use.
FWIW I use IRC Formula Pro RBCC tyres from The Cycleclinic, they really are excellent tyres, grip is as good as it gets in both dry and wet conditions, very P resistant and they wear very well also. There is a version with even better P protection called Formula Pro X guard.
If it’s a road bike ,I’ve found that no sealant will seal above 60 psi and I’ve tried quite a fewMy wife recently got a new bike which was tubeless set up & it has been great for her, as she has no idea how to, or wants to know how to fix a puncture , she's had a couple of visits, but survived. I normally check before she ventures out again & have noticed that they lose pressure more quickly & have to give them 10+ psi a day. However today she seemed to suffer a few punctures, 2 sealed ok, but 1 was very reluctant to seal. Not sure if they tyre is now low on sealent, or if the 'cut' is too big to seal? but at 2-3mm long & a 'nick' i'm surprised. 🤔 Had to stop 4 times in last 10 miles to top the air up in it, so gonna call at the LBS tomorrow & see what they say, but I'm far from convinced myself
What tyre pressures do you run in a road bike tubeless setup ?
