plastic_cyclist
- Angus
Every 12 months is good but I once left for 2 years & there was still a small amount left in. Usually in two years the tire is shot for me & rear even less.How often are you supposed to inject more sealant? I've had the bike since August 2020
Just an update on this, I put more sealant in, and it seemed to have plugged the hole until I was enjoying a nice view mid-ride whilst eating a banana.....I suddenly heard....Hhhhhiiiiiissssssssssssssssssss and a load of Sealant regurgitating around the hole!!Plugs work & are great out in the field but if you’re at home you might as well patch it up from the inside & make sure there’s plenty of fresh sealant inside.
Plug it!!!Just an update on this, I put more sealant in, and it seemed to have plugged the hole until I was enjoying a nice view mid-ride whilst eating a banana.....I suddenly heard....Hhhhhiiiiiissssssssssssssssssss and a load of Sealant regurgitating around the hole!!
Sealant will only fill tiny tiny holes. Any visible hole must be patched or plugged properly.Just an update on this, I put more sealant in, and it seemed to have plugged the hole until I was enjoying a nice view mid-ride whilst eating a banana.....I suddenly heard....Hhhhhiiiiiissssssssssssssssssss and a load of Sealant regurgitating around the hole!!
Yes and that is also a learning experience. I find the worms or anchovy plugs struggled to stay in place at pressures above 50 psi. Suspect they might be better in mountain bike tyres. I will either carry superglue or buy some of those dynaplug things. There are a few techniques to learn that you can’t easily practice until needed. Having had a bit of a nightmare I feel I’ve learned a lot About what to do next time.Sealant will only fill tiny tiny holes. Any visible hole must be patched or plugged properly.
I'm not at all sure what a "worm" or "anchovy" plug is. I can comment the plugs which come with a Dynaplug kit work with pressures up to 70psi. I'm riding tyres plugged with this kit ranging in pressure from 45-70psi. My oldest plug was put in last February.Yes and that is also a learning experience. I find the worms or anchovy plugs struggled to stay in place at pressures above 50 psi. Suspect they might be better in mountain bike tyres. I will either carry superglue or buy some of those dynaplug things. There are a few techniques to learn that you can’t easily practice until needed. Having had a bit of a nightmare I feel I’ve learned a lot About what to do next time.
Could be it was in not tight enough. However plugs are supposed to put you on until you get home. When home you can do a proper patch up on the inside. I’ve never had a hole big enough to worm in many years of Tubeless.I wonder what i was doing wrong when I used a dynoplug. I gave up on tubeless because my experience was they don't work but obviously they do for some people which is strange.
