tubeless, to be or not to be?
Sim2003
Looking at this tubeless thing myself , Im sure when I got my bike they said It was tubeless ready. Do I need specific tyres ? if so how do I know if the tyres I have already are suitable, I have Bontrager AW1-Hard Case 700x32c. I had a look on the Bontrager site and they do a step by step on putting in the sealant but not much else is explained.
"Your bike came with Bontrager TLR wheels
If you bought a new Bontrager RXL, RL, Race or Aura 5 wheelset with TLR technology, your wheelset purchase included the rim strip and valve, so all you need is tires and sealant."
Andrew_P
In between here and there
Some say you do not need tubeless specific wheels just need to make the wheel airtight. Personally speaking I would rather a two way fit wheel. You definitely need specific tyres Hutchinson, Schwalbe and Bontrager all do them they are much thicker and stiffer than most tyres. and have a special bead on them, or at least a strengthened bead. Bontrager Race TLR 2013 appear to be tubeless ready, but you need a kit
http://road.cc/content/review/152930-bontrager-road-tlr-upgrade-kit
It looks like it has the bead but the wheel is not sealed, my Fulcrums Two Way Fit are ready sealed all I needed was the right tyre and sealant.
screenman
I run some cheapo Maxxis tubeless, in fact we have not found a tyre yet we cannot run that way, that is on the MTB's though.
Sim2003
@Andrew_P Cheers for the fast response. I'm reading up about it at the moment, I have to say there is very little real info on it all.
Just something I was thinking about doing when my tires need changing. Purely because I can. Have plenty of time to read about it and get some more info. I may just ask at the store when there next month although If I do that I will most likely come away with it too.
oldgreyandslow
Farnborough
I now have the tyres, just got to decide on the kit, there seems to be a wide range in terms of cost. stans seems to be the most expensive, no flats joes less so, are there any other options?
Andrew_P
First time in 3000 odd miles that I had one not seal enough to just top up with air, tried putting some more sealant in and blasting with CO2. Failed Soaking wet dark raining 6 miles from home. Two options walk or try and get a tube in. What a daffodil of a job at the roadside! Absolutely stunned I managed to do it without pinch the tube. No way could you patch one in the dark and rain, it would be a struggle in daylight without a decent rag and something to clean the inside out with
