Trouble with rear gears
gazza81
gazza81
Edenbridge
Ok great i didnt so thats good, i was going to remove and add some but wont bother.
Well ive just had a go with the alignment tool but screwing it in the thread is really bad on the hanger and it only went tight once right in, only a couple threads left on hanger so im going to order a new hanger now!
500502
Do i need to find one EXACTLY the same as this as flicking online and cant seem to see one that looks identical
C R
Worcester
You should be able to find one looking for a hanger for your bike model.
gazza81
gazza81
Edenbridge
Right, hanger turned up today, used tool to straighten but STILL doing exact same thing!
I have to screw tension screw cable for it to go up through the gears which it does then it comes down and stops at the second smallest ring, i then have to unwind the tension screw for it to go into the two smallest!!
Getting pretty f'd off with it now
gazza81
gazza81
Edenbridge
I can get it going up and down nicely untill the smallest cog now, thats the same problem the guy i bought it off had
It comes down to the third smallest then i have to click twice for it to go into second smallest but wont go into smallest
raleighnut
Did you fit a new section of outer where it leaves the frame and enters the derailleur, that tightly curved part is notorious for causing this problem.
gazza81
gazza81
Edenbridge
Yeah, replaced all the outers.
The only thing there is where ive been playing withi ot so much the tappered end of the outer, a little rubber tube like bit has come off but it was doing this problem before anyway
Ajax Bay
East Devon
C R
Worcester
I'm no expert on 105, but I think it has been mentioned before, the angle of the cable exiting towards the clamp doesn't look right I'm the first photo.
