al-fresco
Growing older but not up...
- Shropshire
One chainwheel on the front, one cog on the back - it's the future I tell you!
So what do you consider my 39-53 as? (11-25).
What I knew when I opted for a standard double over a compact however, was that I didn't want to compromise a bigger gear downhill or on the flat for something better uphill. The compromise was a larger (28) sprocket on the back which may or may not be enough for you in any given circumstance, hill or mountain depending on your own ability.
I'd say then that that is the real question Rob, compact equals smaller gears than a standard and the trade-off comes in having more scope on the lower gears. Like me you might find that an 11-28 standard is a compromise, whilst others might find that too much of a gap between gears.
Best of luck.
i saw in a sience ish type mag in the docs or some where an atice on a machanicia drive that gave a sort of varible if not infinit drive? anyone eles seen it of was i dreaming?german i think
