I have a 2012 Triban 3. Learning how to service it all myself. Last weekend I stripped down the front and rear hubs, replaced the bearings and then indexed the gears.
The front derailleur has always given some issues. I thought I'd have a play with it and ended up making it worse. At the start it wouldn't change down to the smallest ring at all. It would go to the middle ring but then sometimes wouldn't change back up to the largest. There didn't appear to be a barrel adjuster like on the rear but reading around it appears there may be one in an odd place? Is there one? I tried tightening up the cable but that left the cable so tight it wouldn't move at all. Also the lower limit adjuster moves the front derailleur but the upper limit one does not move it at all. Therefore I'm wondering if I have a broken front derailleur? The cable also has become fairly frayed at the end so I think I would be better off replacing it.
Is there anything obvious I'm missing here? Or would I be better having a LBS take a quick look? I only need the largest cog for my commute. I shift to the middle cog only on a few very steep hills I'd ride on weekends. I've therefore left the chain on the large cog and tightened the cable to keep it there.
As to the rear it now changes from largest cog to smallest very smoothly. However, changing the other way, smallest to largest, isn't quite as smooth. There's some noise when you change that way which you can eliminate by changing to one smaller than you want then shifting back to the larger one. Everything runs smoothly again. What do I need to adjust to sort that?
