Trek 7.3 FX hybrid crank set replacement
Gixxerman
Market Rasen
At some point in then near future I will need to replace the crankset / chainwheels on my 2009 Trek 7.3 FX.
Replacing just the chainwheels would be OK, but it looks to be cheaper to just replace the whole crankset.
I would like to retain the current gearing if possible (as as near as I can). The bike uses the old style square BB attachment method.
I would also like to keep the chainguard as I often ride casually with long trousers on. I can do this either by buying a crankset with a chaingaurd fitted, or one that will accept the current one (which is held on by 4 screws).
The trouble is that getting cranksets / chainwheels is difficult as the chainwheel tooth sizes are somwhere between road and MTB (which is kind of expected for a hybrid).
The standard crankset is a Shimano Acera M361 with 48/38/28 rings.
After much trawling of the internet, I have found a orginal OEM crankset.
Now I have not had any issues with the current crankset regarding it's quality, so I would be happy to replace like with like. But just out of interest, I might get something a bit better.
There seems to be a Shimano Alvio 411, but it is quite difficult to get hold of.
A hollowtech deore would be nice as it would save a bit of weight, but I cannot find any with the correct gearing.
Any suggestions?
cosmicbike
Perhaps This One.....
Egham
Replace like for like. If you had no problems with the first set why spend more money upgrading a part which will give very little, if any, noticeable performance increase.
That's what I'd do...
