Richard A Thackeray
With regard to the 2 posts above, she's also thinking of a Karoq!
A 2 Skoda family!,,
A 2 Skoda family!,,
Have you fired everything up? Heating, fridge, water, cooker etc? My water system needed a small overhaul when I tested it a couple of weeks ago. I also discovered that the ignitor on the fridge needed a new battery.
The water pump's not playing fair!Have you fired everything up? Heating, fridge, water, cooker etc? My water system needed a small overhaul when I tested it a couple of weeks ago. I also discovered that the ignitor on the fridge needed a new battery.
We did that yesterday with an emery board, to no effectTry cleaning the terminals at the caravan exterior, ours used to play up first time out after winter, cleaning the terminals sorted it
Oh dear, you’re going to be popular,I forgot!!!
The area's inundated with Red Kites!
I have no idea whether they're nesting in the Harewood Estate, or fly over from Bramham Park (I've seen them there a few times, as a family friend has his own caravan there)
Big birds!
Wife rang me earlier, to tell me that 'Dr Google' diagnosed it
Apparantly, there's a white box under the offside front seat (240 - 12v transformer??) & that had blown a fuse
Now they have hot-water
It still leaves me 'in the bad books' for filling the cistern, on arrival, with (diluted) 'blue' that goes in the toilet-tank![]()
As always......................Oh dear, you’re going to be popular,glad the pumps sorted
You're showing your age trying to repair something before consigning it to the bin.Nice result today - the roller blind on the toilet window had lost tension and was impossible to open without getting rucked up. I went out to measure it in anticipation of replacing it but as I studied it it noticed it was easy to remove… so I did. Then I studied the mechanism, removed the roller, freed the sticky tensioning setup, reassembled it, retensioned it and boom…. it works perfectly and I don’t need to replace it for £90.
I can’t help it! I’ll admit that as I was dismantling it I was expecting a ‘twang’ and a load of springs and pawls to go flying off to another dimension, but it turns out it is quite a simple mechanism and nicely designed for overhaul.You're showing your age trying to repair something before consigning it to the bin.
Iirc the tension can be adjusted with a screw driver at the side of blind, losing tension was why ours never got left down over winterI can’t help it! I’ll admit that as I was dismantling it I was expecting a ‘twang’ and a load of springs and pawls to go flying off to another dimension, but it turns out it is quite a simple mechanism and nicely designed for overhaul.
