Ajax Bay
- East Devon
You may find this Sheldon Brown page worthwhile reading with some technical specs. Please don't take some of the comments above as 'adverse': I'm sure they're not meant like that.
My god that's a lot of reading, might tackle that just before I go to bed, should help me sleep, only kidding.You may find this Sheldon Brown page worthwhile reading with some technical specs. Please don't take some of the comments above as 'adverse': I'm sure they're not meant like that.
"hi , all modern bikes have a 35mm threaded part , unless you've got something unusual this will fit no problem cheers", was the answer a seller from Ebay gave me when I asked the question, a brief read of Sheldon Browns page doesn't say this exactly, so we'll have to be careful matching the hub to the freewheel.You may find this Sheldon Brown page worthwhile reading with some technical specs. Please don't take some of the comments above as 'adverse': I'm sure they're not meant like that.
This is the important bit. Or as your ebay seller saysThe issue is that you don't have a hub. You have an axle with a wheel on one end, and a sprocket bolted to the other.
. So your tame mechanic will have to source a hub, with its "35mm part", fix that to the existing axle, then screw the freewheel on to that. From the photo it looks like your axle has an M16 nut on it (24mm across flats) or possibly M12 (19mm across flats), so I see an amount of welding in your future.unless you've got something unusual
Well it wouldn't be a bad thing if you were out, your negativity is depressing. However, for the benefit of those who want to know, the hub is to be modified by turning off the threaded end flush with the rear of the spoke plate. That will then be clamped / bolted to a replacement sprocket collar, minus the sprocket. The new 6 cog freewheel will be threaded onto that. I'll try to show a mock up of the proposal for those interested.The issue is that you don't have a hub. You have an axle with a wheel on one end, and a sprocket bolted to the other. I'm sure you're not going to listen though, so I'm out of here.
Well, while searching for suitable components to P/shop into a mock up, I came across a series of Atomic Zombie pictures which explain how I intend to modify my trike. Unfortunately they aren't manufacturing the threaded collar/ hub or I may have taken the easy way & sent for one. If you click the link at the bottom of the AZ page, they do supply drawings which could be modified to suit my dimensions.Well it wouldn't be a bad thing if you were out, your negativity is depressing. However, for the benefit of those who want to know, the hub is to be modified by turning off the threaded end flush with the rear of the spoke plate. That will then be clamped / bolted to a replacement sprocket collar, minus the sprocket. The new 6 cog freewheel will be threaded onto that. I'll try to show a mock up of the proposal for those interested.
Been having a chat with the Aussie trike manufacturer, the one I thought his rear end may be an option. He said my set up with two brakes on the front wheel wouldn't be allowed in Aus'. The problem fitting gears & a rear disc is the control cables, if the controls are fitted on the handle bars, they would have to be removed every time I put the trike in the car. The speed I'll be doing wouldn't warrant a rear disc brake, so that's on the bottom of the priority list.
You only need the flange if you're bolting a disc brake on, a modified version of that should serve the purpose though.
I'd go with the first drawing set up, just remember that the derailleur needs to sit at a perfect 90 degree angle to the bar you mount it to.My proposed bike ride this afternoon was curtailed, partly the weather but mainly as my rear r/h tire had deflated, the pump supplied with the trike wouldn't, so the only exercise I got was assembling then dismantling the trike. This was countered by the rum & raisin cornet my wife bought as compensation.
So I came back & knocked up a couple of drawings.
Think actually the hanger needs to be in a plane perpendicular to the axis of the block of sprocket / driven wheel axle, rather than in relation to the bar onto which it's mounted.the derailleur needs to sit at a perfect 90 degree angle to the bar you mount it to.
