This terminology would be more familiar, perhaps, 60 years ago! A quick google search would've allowed you to discover
this. AKA a 'straight block'.
From my post #4 (to which I referred btw, in case you wanted detail): "a 14,15,16,17,18, 20 freewheel". One with mostly only one tooth steps. You've said you'll be cycling only the slightest of gradients and aren't "racing" so the range you will want is small.
But first I recommend you consider and then specify what range of gears you want. How much higher than your current 0.76 (18")? How much lower?
@Tim Hall has interpreted the diameters to teeth (am surprised that you are not able to count them yourself btw) as a 26t sprocket and a 20t chainwheel.
I've produced a
gear calculator for the 20t chainwheel and the freewheel above. Click on it and then you can fiddle around with it. The gear inches are at the top.
Finally, it may be that you'll find it easier to take an old, discarded half a hub (freehub driveside) from a wheel which is designed to take a cassette, rather than a freewheel (such as the one you've imaged), as this might be easier to fit to the current set up. There may be chain width issues if you do, though, as you're probably on 1/8" chain. And consider chainline as this will be aligned with your current sprocket and a 6sp freewheel will push the chainline well over on the small sprocket.
