Top speed. Chain rings ?????
Doyleyburger
Doyleyburger
NCE West Wales
Agreed !
But I am finding the hills ok which is something I DO NOT want to sacrifice instead of getting better top speed. If there was an option to change the gearing without sacrificing the climbing then I would be up for doing it. Never mind, was just wondering about it
IIRC I fitted a SRAM 8spd 11-26t cassette to my Sirrus, in theory that will make you spin out less but as Rob says at high speeds its more about technique and aerodynamics; FWIW, the fastest I've been this year (45.6mph) was on a cyclocross with only a 48t big ring.
Agreed !
I'm pretty sure we did this exact same topic a few weeks ago. Did you ever find out what gearing your mates were on? My guess is that it will not be a lot different to yours.
guitarpete247
Just about surviving
Leicestershire
Overconfidentii Vulgaris
Is there significant difference to be gained by moving from a 12 to an 11?
By my calculations it'll give approximately 11 gear inches extra at the top end.
zizou
When you get to the mid 40s mph there is more speed to be gained from technique and tucking in rather than continuing to pedal.
It will certainly give you a bigger gear but whether there is anything to be gained from that is debatable. Eddy Merckx and others of his generation were on a max gear of 52x13 it didnt hold them back too much
Paulus
Barnet,
Moving up to a 53 chainring will increase your top speed a little, but, it will make it a bit harder, as would changing the rear sprocket to an 11. If you have the legs to power along in a 53/11 you need to join a club that specialises in racing.
