potsy
Rambler
- My Armchair
^^^ Triban 7 it is then
I think I am leaning back towards the Caad 8 now, can always flip the stem/add spacers like you suggest Colin.You've seen my CAAD 5 ...
After riding it for a while with its original racy position, I came to the conclusion that I needed to sit more upright. I couldn't achieve that with spacers under the stem because the steerer had been cut too short for that so I flipped the stem over. The position now is perfect for me. It doesn't look as nice as having the stem the right way up though, so if possible, having extra spacers is the way to go. If you would do that, then the CAAD range should be back up for consideration!
I've got a CAAD8 105, and tried it against the synapse. Absolutely great bike, not too aggressive position, and you have the option of flipping the stem if you need which kind of gives you a synapse option.
Quite timely I've just received an email from my lbs about the new Trek Domane, in store nowI do like Cannondale bikes, but at this kind of price point I'd also take a look at the new entry level Trek Domane.
http://www.bikeradar.com/road/gear/category/bikes/road/product/review-trek-domane-20-13-46914
Does look good, would rather buy from somewhere I can see the bike beforehand though, not keen on an internet sale at all.I'll be honest mate. If I was buying a bike around £1k, then I'd find it hard to get past the Canyon Ultimate AL 7.0
The spec is brilliant.
Good to know, thanks adamhearnI had a similar choice a couple of years back (CAAD 8 vs Synapse). I chose the Synapse after a back to back test ride on the same route. For me it's the right bike - not a racer but is fast enough for what I use it for.
Your original thoughts of fitting the 105 calipers may not work on the Synapse as it requires long drop versions. I've not measured but it's possible the 105 units will not reach.
I think it may take full mudguards too. It was one I considered when I was looking for a winter/bad weather bike. Couldn't quite stretch my budget so ended up with a Forme Longcliffe.Good to know, thanks adamhearn
I have the choice of taking the better bits off the Secteur to put on the new bike or keep as is and use as my winter commuter, do you know what size tyres could fit the Synapse?
Just wondering if they have the long drop brakes because of the frame difference or to accomodate wider wheels.
