Roseland triker
Cheese ..... It's all about the cheese
- By the sea
Good luck.I haven't tried that , can everyone else agree to bolt out from the frame rather than into it ?
Solutions above: choice will depend on your expertise. But "any ideas" how you did the threads in? The hanger presumably bent/broke in your mashing. That won't have done 'em in.I may have done the threads in
Go careful. Aluminium dropouts are not idealWhatever happened when I came off the hanger didn't even brake as I believe it's meant the whole hanger was still attached to the derailleur with the two screws inside
Hey what's the name of these bolts and sleeves so I don't look a mug when I go the hardware shopThese or similar are widely available and should be appropriate, if I understand the problem correctly:
Establish the best size, then drill out the hanger and fit with the hex bolt head facing out. If you can get the size just right, you can make the hole exactly the same size as the female threaded sleeve; then heat the hanger gently and push in the sleeve from the back. When the hanger cools it will grip the sleeve tightly. With an aluminium frame, be very careful not to use excessive heat — the hanger will melt. A hair dryer should be fine (definitely not a paint stripper!).
Sorry just clicked on the link , thanks a lotThese or similar are widely available and should be appropriate, if I understand the problem correctly:
And zip ties !Duck tape
Hey tried it from the other side , worked at treat hangers on and rock solidIll give it a go
PicsHey tried it from the other side , worked at treat hangers on and rock solid
