Chris S
- Birmingham
What's so special about Loctite? Is there any reason why you can't just use something like Bostick?
This I think is the main reason for it's use in most situations, rather than any mechanical justification.Some parts are supplied with threadlock already on the bolts or male threaded parts (e.g. brake calipers, stem bolts) and I wonder if they do this for fear of litigation in case someone suffers from something coming loose and then deciding to blame the manufacturer.
)he used CAPITAL letters
liked but not going to share your cheaper source with us?I use this
Amazon product ASIN B07VJ3XM9WView: https://www.amazon.co.uk/Bond-A43-Threadlock-25ml-threadlocker/dp/B07VJ3XM9W/ref=sr_1_18?crid=19WVE7ULTVSJ&dchild=1&keywords=thread%2Block&qid=1605693124&sprefix=Threa%2Caps%2C207&sr=8-18&th=1
Not from this seller got it cheaper.
Used loctite but this seemed just as good. Twice the amount for half the price.
liked though i haven't a clue what the last four words mean.I'm a big fan of nyloc nuts, especially on hot exhaust manifold studs.
for real belt and braces some "chicago bolts"?Repaired a suitcase yesterday Samsonite. Huge hard case. Use it when foraging/scrounging when holidaying. Bringing back cider from Herefordshire etc. On the way back from Herefordshire the whole pull handle came off. The lot just ripped of when I was changing trains.
Used nuts and bolts with washers and thinking about whats been said on here about threadlock being completely unnecessary, lashing and lashing of threadlock.
Belts and braces.
"THERMAL PROPERTIES Most nylon insert locknuts are manufactured from Zytel 101 which has an effective temperature range up to 250 ° F. Zytel 103 has a higher effective range to 350 ° F and can be special ordered for your higher heat applications. The insert is available in a wide range of colors: white, green, yellow, red, orange, purple and blue to name a few. The coloring does not add or take away from the performance and is mainly used to identify the manufacturer. Nylon is the most resistant thermo-plastic resin today. As temperatures increase, it will retain resistance to softening until the maximum degree is reached at which point it melts immediately. On the other hand, with a decrease in temperature, the tensile strength increases and it will have excellent flexibility allowing locking action to continue even in sub-zero temperatures."I'm a big fan of nyloc nuts, especially on hot exhaust manifold studs.
I think master @Drago may have not been entirely serious in his suggestion ..."THERMAL PROPERTIES Most nylon insert locknuts are manufactured from Zytel 101 which has an effective temperature range up to 250 ° F. Zytel 103 has a higher effective range to 350 ° F and can be special ordered for your higher heat applications. The insert is available in a wide range of colors: white, green, yellow, red, orange, purple and blue to name a few. The coloring does not add or take away from the performance and is mainly used to identify the manufacturer. Nylon is the most resistant thermo-plastic resin today. As temperatures increase, it will retain resistance to softening until the maximum degree is reached at which point it melts immediately. On the other hand, with a decrease in temperature, the tensile strength increases and it will have excellent flexibility allowing locking action to continue even in sub-zero temperatures."
PS I'm am not suggesting that threadlocker would be any use in this employment.
