So on your (or others') bikes where do you use threadlock, then? Or are you saying that no fastening on a bike is "in a (sic) high vibration"? Is the use of threadlock a suitable mitigation to minimise the risk of failure of fastenings where the threads are damaged?
I cant think I ever used it on a bike. I'd consider myself to have a degree of mechanical sympathy, I don't over tighten stuff, its extraordinarily rare for something to come loose on any of my bikes so I don't consider it needed or useful. That said, some might. I'm not against its use, just don't need it myself.
I have some in my work toolbox and we have some vibrating equipment (conveyors / feeders etc)I 'might' use locktite on.
Damaged threads ?....its not good practice of course but sometimes, usually, speed is of the essence, you might have 30 people on £9 hr waiting while I fix something. If I happen across a damaged thread or bolt (often in an aluminium gearbox housing, 1 damaged thread of 4 for instance...or an air operated flap that's moving 1000s time a day) of course I can fix it properly, rethread it, replace a slightly ropey bolt...but that takes time while a quick shot of thread lock can make an acceptable compromise until a later date. It's a decision made on the job, depending on the degree of play, acceptability, length of time it might last etc etc etc.
But even at work on a day to day basis, no, it's not really used.
I've also worked on some vibratory equipment where you absolutely would use it every time.
