deano69
- kent ( Garden of England )
I have a fairly new set of alivio crank / chainrings on my bike and decided today to take then off strip down the bike as frame is being powder coated.
The opposite side of the chain rings came off easily with the crank puller tool but the chain ring side .....NOT,
I threaded the puller tool all the way in till tight then turned the other part to release from square spindle then all of a sudden the whole tool pulled out through the threads stripping them and leaving the crank well and truly on there :O( .
Now how do I remove it a good whack with a 4lb hammer ??? I tried prizing it off with a large flat bladed screw driver but dont want to dent or damage frame and bottom bracket is tightly screwed in holding the whole thing firm will a good whack shift it from the spindle ?
Cheers,
Deano
Cheers,
Deano
