Or, rather than being a fact, it could be a subjective opinion....
No.... it's definitely a fact they are ugly.
( I await the Campagnolo version which undoubtedly will be beautiful but not work quite as well...and need a £100 tool to adjust)
Modulation is a buzz-word that's easily overused but it does merit some explanation. I would define it as fine and predictable control of the brakes...
Futher, modulation is good when the movement is smooth. Gritty cables don't offer good modulation but delivers increasing and decreasing stopping force in jerky curves. Drum brakes, be it on a car or bicycle, don't modulate well. They have a self-servo action that catches you with surprise lock-up.
... disc and rim brakes will provide exactly the same stopping force ... In the dry, the two are exactly the same and can't cause a peloton pile-up.
On modulation, isn't the fact that some older V-brake and non-Vbrake systems weren't linear a bit of a red herring unless the peloton are still using them?
Isn't the reason car drum brakes have that action because they are designed so that in operation, the shoe tends to wrap to the drum? Rim brakes don't have that action.
Surely braking force is dependent on friction material YES, surface area, NO leverage, actuation NO, but leverage yes etc. etc. and thus will be very variable from design to design and between rim brakes and discs? Or are you thinking of other limiting factors (tyre's grip on the road, rotational moment around the front hub, how heavy the guy who might be thrown over the bars is, etc.)?
Rotational movement at end-over limits is around the road contact point, not hub. But I'm not sure what you want me to be thinking of?
Yes, but I wanted to keep it simple and just stick with COF. But now that we're on it.Surface area can affect braking performance (Don't know how to quote the post you quoted).
Though probably not in the way @HF2300 is getting at. But if you're heating the material beyond optimum performance limits, an increase in surface area to dissipate heat under braking will improve performance. Similarly, if you're not getting enough heat in to get them to optimum temperatures, a reduction in surface area will improve the effective of the system.
Not quite, they were completely useless...the only reason for using them was if you got paid to do it, and there is a point at which the money/danger of injury equation tends towards looking after the injury risk.- or you spent the money on medical bills!Looks aren't everything. Otherwise we'd all be riding with those lovely looking Campagnolo Delta brakes which look absolutely beautiful but which reportedly were not terribly good brakes ... or at least were very hard to set up.
Sorry, I just read your post again. I assumed you were talking about larger surface area on tyres and answered that non-question.Surface area can affect braking performance (Don't know how to quote the post you quoted).
Yes, but I had to define modulation first so that I don't get bitten on the arse by the but...but...but crowd. Hence the mention. They are exactly what modulation is NOT.
? OK, with you.A good feel could still provide poor modulation, I'd say..
It isn't the design, it is a by-product of the design and an undesirable one. All brakes nowadays are power-assisted and don't require self-actuation.
Surface area can affect braking performance. Though probably not in the way @HF2300 is getting at.
Having seen the injuries supposedly inflicted by disc brakes (a bit like being gouged by a blunt serrated edge knife) I think they should be banned until a form of shrouding is fitted to the disc/caliper.
What way did you think I was getting at?
