An order has been placed for the Schwalbe Pro One 700-28 tyres + the Schwalbe sealant. The wheels are Fulcrum tubeless ready and they recommend Schwalbe stuff as being the preferred combination.
Time will tell!
Rob
A couple of tips
If you've got access to a compressor, it will make inflation so much easier. You will hear two pops as the bead seats
I tend to inflate dry without sealant, then pop the bead and pour in 70 mil and refit the little bit of bead. I inflate to around 40 psi and press the tyre hard on the ground to bed the bead around the entire wheel. Roll the wheel in all directions to coat the entire tyre innards. Inflate to a pressure which offers good roll and comfort. All your previous ideas about tyre pressures will need resetting- tubeless can be 20/30/40 psi lower.
I tend to inflate, so tyre doesn't feel to roll under cornering.
