numbnuts
- Gone over the hill and far away
£95 for a rear light !!! out of my price range, I’ll just stick another candle in the lantern that should do it
The hope light is made using three 240-lumen LEDs.
Can that be correct, if so that is going to be one bright rear light.
http://www.bikeradar...d-freehub-27582
The best thing for visibility is a high viz jacket, and reflectors.
One of the most useful rear lights I ever had was a set of bar end lights that flashed. Fitted into the drops and facing rearwards they seemed to work a treat. Cars definitely gave me a wider berth than when I ride with just a seatpost light. Unfortunately the batteries cost a fortune, didn't last more than a couple of weeks at a time and the whole unit let in water and rusted up![]()
If I could find more bar end lights for drop handlebars I'd buy them again happily![]()
I can't really see how the current situation as regards bicycle light legislation can continue given that every year lights get brighter. There is no law in situ that prevents you from running for instance, the new Exposure Six Pack rated at 1800 lumens, great for off road, but on road? These sort of lights are going to burn a hole in the retinas of the drivers of vehicles coming the other way, not big and not clever. I get flashed after cars have dipped their lights coming towards me and I've only got the Hope Vision 1.
The usual response to this from [some] of those with trillions of lumens is along the lines......that'll show em; now they will see me: serves the b........s right etc etc.
Unless your dynamo has the circuitry to control the output voltage, you will probably want a driver. What happened to the ones you previously had?
Just because it needs say 2800mA @ 900lumen, doesn't mean that is the most efficient
Drivers can be had for a few quid anyway.
You are making my point for me, the ideal place to centre your front light beam is approx 5 metres ahead on the road. The problem is that front light reflectors [with the 2 exceptions mentioned] are not designed to limit their spread in the same way a dipped car headlight is.If you're getting flashed with a Hope 1 you are just facing ignorance... a small 10 Lumen LED will look "too bright" if pointed in the correct direction - I've even heard people moaning about seeing spots after looking at some 2 lumen LEDs.
