Bar mount tests with the new firmware:
Having Steadyshot on was not a good idea with a bar mount - I tried it and the vibration seemed to throw it; the picture jerks and bounces.
So, with Steadyshot off, I tried some other settings for bar mount use:
1. 1080p 30fps 120 fov - ok, very little rolling shutter, but quite a few jumps with bumps in the road surface.
2. 1080p 60fps 120 fov - same as 1, except for a little more artefacting (blocky squares passing roadside vegetation).
3. 1080p 30fps 170 fov - much smoother than 1 or 2, the wider field of view pushes foreground movement into the background, reducing its amplitude. Good picture quality but still has compression blocks.
4. 1080p 60fps 170 fov - no better than 3 in terms of vibration effects, compression blocks seem a bit worse.
The Sony is actually very good at handling rolling shutter with the narrower 120 degree fov at 30fps, certainly better than my Contour+ at 1080p and 125 degrees. It seems better than with the old firmware although it is difficult to be sure.
This means there is little or no advantage to moving to 60fps as a way of minimising rolling shutter because 1080p is handled ok at 30fps, with a slightly better picture quality. 60fps 1080p also seems to significantly shorten battery life. The problem with both 3 and 4 above is that while you get a decent picture, the wider fov brings your hoods well in shot.
Regarding blocking/compression issues - it is only a problem with leafy roadsides, or in other words, almost any rural location. It seems ok going past buildings, probably because there is less detail and colour variation to process. There's a new mounting frame coming out, so if Sony implemented better compression, particularly for 720p where the data rate needs almost doubling, and got rid of the blue/green tint the camera would be a much better market contender.
Bar mounting - my conclusion is that on a smooth road, I would choose 1 as it has better picture than 60 fps, smaller files than 60 fps, more natural fov, no hoods in view. On a surface-dressed lane I would go for 3 as it gives a smooth picture on a rougher road.
