Just compare gerrards contribution to that of pirlo.
Pirlo shone, Gerrard grafted.
Paul Scholes at his best, Xabi Alonso and Pirlo himself would've struggled in a similar way for a foothold in that England set up. I'm not a great student of the game but sometimes it's so obvious one doesn't need to be. It wasn't the players, it was the tactics that ceded possession. It's Roy's infexible philosophy, it's how he believes the game should be played. Believe me, I watched Liverpool play the same way when Roy was in charge even against teams with far inferior players.
How can any of England's midfielders shine as an attacking force when the ball flies from goalkeeper to centre forward time and again? How many times did Gerrard receive the ball in ten yards of space in the Italy half with passing options? Pirlo was in this situation virtually everytime he had possession.
Here's what Roy Hodgson said after the defeat: "I don't regard statistics, especially possession statistics, as being particularly important."
He's all for ceding possession and focussing on using the ball better when it eventually breaks for his teams. Throughout the group stage this is what happened and Gerrard DID use the ball well in those moments setting up three goals. This is entirely different to the way in which Italy played.
Here's what Gerrard said: "I don't look at stats too much unless it's clear, time and time again, that something's sticking out so obviously. It's one of the biggest points the management and coaching staff will have to look into. They have to analyse why we aren't keeping the ball better. Especially at this level because it's fundamental, and it's the key if you want to beat the big teams. You have to keep the ball, otherwise you work so hard without it the other side end up running you into the ground."
