Ivan Ardon
MacB said:I'd replace handlebars if they were crash damaged, same with forks.
+1
Listen to what the man says if you have alloy bars and value your face / teeth / head.
Bummer! Many sympathies - and all credit to you for having emerged cheerful enough to come on here & tell us all about it. FWIW, I've always understood that the basic answer to your query is to set the bars so that the flat sections at the bottom point directly back at the rear brake mounting point.Rob3rt said:Kind of while the handlebars are of topic, does anyone know of a general rule for the rotation of them, as in what angle the drops should be, horizontal, slightly sloped in one direction or another? I realise its probly a personal taste thing, but its good to try out benchmarks and then alter to suit, rather than start from scratch.
Not for me!Rob3rt said:Its got to be a pretty common bike injury right? Since the handlebars are 1st thing to hit the deck.
ASC1951 said:Not for me!![]()
I always set the bolts on my bars so that they can be moved. I do the same with the headset/fork bolt. This setting is slightly looser than the shop sells them at and is at a point where you have to use most of your bodyweight to move them. So when I have a crash like yours, my bars and forks simply twist out of the way, undamaged.
I'm not saying this to sound smug. I have had plenty of offs over the years. We all do - it's part of cycling and the skill is in minimising the damage to bike and rider.
ttcycle said:Sounds like an unpleasant off -I'm also unsure how your bars could have ended up misalligned like that without witnessing the fall- this is probably cautious but I would replace the bar and get the front forks checked out down the LBS as if they have had impact from a crash you cannot be sure they're not going to fail on you when you least expect it.
ttcycle said:Yeah it doesn't sound right, is the bike new? Might be worth taking it to the LBS - though if the bars were misalligned/bent in a crash they wouldn't be covered by warranty - it is possible that they could be bent with enough force
Good grief, are you some sort of gorilla?Rob3rt said:Good idea, but dont they shift when you are accelerating hard and pulling at the bars?
