The best chain lube
battered
I like the approach the motorcyclists use, with devices like the Scottoiler that uses engine vacuum (I think) to open a valve and allow oil to drip from a container onto the chain. I have also heard of a chap who DIYed something similar, it was a bottle tucked away somewhere with a pipe and a tap, set up to drip on the chain once every few seconds. I think he refilled it with old engine oil, the only hazard was that if he forgot to turn it off it would empty itself on his garage floor. I remember that 2 stroke bikes sometimes used to route the exhaust over the chain too, so any oil mist went on the chain.
battered
That'll do it. A bit of a sledgehammer to crack a nut on a bike though, where access is dead easy and workrate low. I used to take a little bottle between 2 of us on Polaris rides, that was enough. Same for touring.
swee'pea99
PS I've been using this stuff for years, and rate it:
But I'm sure there are others just as good.
My mate used oil from tinned fish when he was on a world tour. Down side, blooming ants had a good munch at his toe straps as the oil had got onto his hands, then the toe straps.
Maybe avoid fish oil in warm climates !:laugh:
PS I prefer wet lubes applied sparingly, and not the super sticky stuff !
Ming the Merciless
There is no mercy
Inside my skull
Something stinks about this tale
  • Laugh
Reactions: C R
Spiderweb
Not So Special One
North Yorkshire
I've just got some of this, where ever i was ordering what ever else i was ordering didnt have Squirt in stock, so I reckoned this was worth a try.
is it best to put on the night before and let it dry, think I read that in a review or something
I usually apply an hour or two before riding, it doesn’t dry.
My chain cleaning routine is;
Spray WD40 on to a cloth and give the chain a good wipe clean.
Dot each roller with lube.
Hand spin the crank a few times to let the lube ‘settle in’ and leave for an hour or so.
Give the chain a quick wipe to remove excess.
