If you are building up miles in your legs you WILL need to take care of them. Get yourself a large spray can of anti-freeze and roll back and sides of your legs back and forth in small sections over it. Start off gently as you will be very tender, work from your heal Achilles, up your leg, calf both sides, tendons and back of knee. Then go above your knee if you want to massage your upper leg. Do your IBT if you need to as well if it is sore, although go carefully as it may be tender. You will need to support your body weight with your arms. Do not stretch your muscles but do this instead. You are massaging the muscles and tendons stimulating blood flow, old out and new in. Do before and after you ride or in the morning and evenings when you get up or go to bed. Only need take 5 minutes when you are good at it. When out on a ride legs will feel a lot more supple and stronger. You will look forward to this massage. It is simple and cheap the only cost being that of a can of anti freeze spray. Why anti freeze? It's cold that's why.
Also as others have said you need the right frame size and correct saddle height. When stationary sitting evenly and square on your bike put your heal on the pedal at the bottom of it's stroke - your leg should be relaxed straight to very very very slightly unlocked. If your heal cannot reach the pedal or you have to slide your hip down to the side to allow your heal to reach it then your saddle is too high. Loosen and lower a few mm at a time. go for a test ride and re-assess. Also don't push heavy gears, spin easily and comfortably, obviously not like a kid's windmill spiny thing but so you are comfortable. Keep your knees in toward the top tube as you ride. Relax your upper body and power smoothly around the whole pedal stroke. Don't over do it at this early stage. If you can get a cycling computer/Garmin with cadence function this would be a great aid for you. Try to routinely ride at 85-90 or slightly higher 95 as you get fitter and stronger.
HTH.
