Coggy
As Ian says, you don't want it becoming chronic. An anti inflammatory gel or pills might help
Thanks, that's what I have done this morning. Deep freeze anti inflammatory gel and ibuprofen
I have quite sore tendons in the back of my right leg behind my knee.
Does anyone else suffer with this after a ride ?
If so, what advice do you have please ?
Sounds like the bike may be too big, on tip toes on my bike, I have a good 6 or 7 inches of seat post showing, following a bike fitTo be honest maybe I am being a bit dramatic. It's not excrutiating pain or anything more like stiffness and a dull ache.
Could well be down to lack of warm up/stretching and possibly my seat height although that is not high at all. I am about 5ft 11 and my seat is only a couple of inches above cross bar and when sat on saddle i am on my very tips of toes.
I developed this problem some time ago- always my right leg. A bike radar article advised that posterior knee pain is almost always a result of hyper extending the knee joint. Saddle height of fore aft positioning might be an issue, but are more likely to result in pain further up the thigh.
I worked out that I had developed a bad habit of freewheeling with my right leg "straight" ie with the knee joint slightly hyper extended. I changed that habit and hey presto the knee pain disappeared immediately
I was going to suggest going back to the lbs for advice, but given you presumably bought it from halfords... It might be worth a try anyhow
What size did you get?
However, given you've ridden it 6 times or something, it may just be you need to get used to it. Also find a YouTube guide on positioning cleats, it's a dark art!
Dial down the mileage and let it recover. Going up to 50 miles on your sixth ride, is almost certainly too much too soon
I reckon you've overdone it, on a bike that isn't set up right for you, and with spds, quite possibly incorrectly positionedIt first started after a 34 mile ride last week.
The halfords geometry is rather different I believe, what are the actual dimensions?
Could be a strain rather than tendonitis, which tends to be a more gradual process caused by overuse
Try heat as well as ice and stretch gently, but only after exercise
Seen a doctor?
Quite a long top tube, I ride 54cm bikes and am a smidge under 5'10, however being female, my height is more In my legs than torso
Also really wide bars, I use a 38cm, but again narrower shoulders on the superior sex
They evidently measure bikes on the seat tube. Rather than the top tube like most
My 54cm genesis has a 51cm seat tube http://www.genesisbikes.co.uk/bikes/road/sportive/equilibrium-20
You could perhaps make it smaller with a shorter stem. However, all speculation, sort the saddle and cleat position first and rest for a week
