IDMark2
Dodgy Aerial
- On the Roof
Definitely not, although the splits is a good trick.No banana suit though!
![Cuppa :cuppa: :cuppa:](/styles/default/xenforo/smls/coffee.gif)
Fancy using a gas powered one?Definitely not, although the splits is a good trick.![]()
Powered pogos pose problems post pogo, probably permanent.Fancy using a gas powered one?
Repercussions readily rectifiablePowered pogos post problems post pogo, probably permanent.![]()
Spring sticks? Slippery spray saves some.Repercussions readily rectifiable
Winter walkers! Waders will work wondersSpring sticks? Slippery spray saves some.
My brain hurts now...![]()
That'll be shepherd or cowboy then.![]()
That's what it looks like , job search has been fruitless sofar![]()
Mischievous mongrel made messYou yellow Yorkshire yomper...That's it, we've surely done it all now, even in alphabetical order since the p's.
Perhaps you'd like to check who started the banana suit off!Nooooooo....don't start him off on banana again!![]()
Got their number, its 6 digits not five by the way![]()
Ooops....sorry.
