- Next door to Mr Benn at No 54
I can recommend Lindt white chocolate!
But I can also recommend any Lindt chocolate of any description.
Either get used to it or sell it on Ebay and lose a load of money... looking to see if we can turn it upside down to avoid seeing the pressed metal convector fins spot welded to the tubes that ruin it, but that needs 2x 15mm to 8mm dia. chromed connectors which no-one makes.... for the very good reason that it reduces the efficiency of the radiator flow.I hope you get it sorted.....not sure what to suggest![]()
It would make a very good radiator...Could NT turn it into a cycle driven food blender?![]()
I want to fit taller front wheels to the tractor (16" is a little too small) and did consider it as I have five of them.I'm hoping that you'll transfer those spoke wheels to the tractor - they'd look really special![]()
I want to fit taller front wheels to the tractor (16" is a little too small) and did consider it as I have five of them.![]()
Well, it is a standard car set. I just didn't want to get rid of any until I was sure how many I might need, a bit like the cast iron baths.Only you could accumulate 5 wheels....![]()
How many calories have you got left?![]()
