randynewmanscat
- Vienne, Poitou-Chrentes
The longest BB axle I can lay a hand to is a 68/117mm Shimano Deore loose balls.
It's too short, probably by 2mm. I thought it would be close but the 29T inner ring kissed the chainstay before the wrench would have clicked.
It's JIS both parts and the taper was in no danger of running out, it looks right.
If you have or had a Zephyr triple
what length axle did you use?
For an added complication the Shimano spindle is asymmetrical, it is 1.5mm longer on the RHS so 118.5 if it was a contemporary piece.
