Swapping wheels and disc rotors between bikes
simonali
Flippin' blimey, the SRAM rotors are nearly £60
a pop!
:eek:
And they're only 50 bucks in the US of A.
smutchin
Cat 6 Racer
The Red Enclave
I do have a cassette tool, but it probably dates back to when they only had 7 cogs!
I'll be fitting a new SRAM cassette, too. Will that be a different tool?
Should be fine. SRAM and Shimano cassettes use the same design lockring, and I'm not 100% certain but I think 7-speed Shimano cassettes use the same lockring as 11-speed versions.
simonali
Cool, sounds like I have all the gear but no idea!
Basically, I want a set of wheels with road tyres on and the other set with gravel tyres on and to be able to swap between the two as required. I think my only issues will be aligning the rotors with the calipers and making sure the rotor designs are similar so I won't have issues with slots etc wearing the pads differently?
simonali
Buggery ballbags! The wheels have arrived and they came with externally splined lockrings. Just looked on Park Tool's website and the wrench is 35 quid!
:B)
T4tomo
I did this for my winter/ gravel / do it all bike and it works a treat. TPR Hylex brakes and no issues switching between wheelsets. I just made sure the extra wheels were same 6 bolt fitting as original ones.
T4tomo
I can't find anything about tools on the Shimano website. It's the same tool as a Hollowtech BB apparently. I might just get it all assembled and get a LBS to tighten them up for me. Have ordered some rotors for 48 quid each. This idea of swappy wheels is becoming more expensive by the minute!
http://www.chainreactioncycles.com/mobile/park-tool-bottom-bracket-tool-bbt-69-2/rp-prod173237
£48 rotors? F**k me mine were a fiver each http://www.wiggle.co.uk/cycle/road/disc-brake-rotors/?ea=4294789698
JhnBssll
Suffolk
Two things; centrelock rotors won't fit on 6 bolt wheels, there are no adaptors as its not physically possible. 6 bolt rotors would fit on both sets of wheels but would need an adaptor to go on the centrelock wheels.
Secondly, I have a pair of lightly used SRAM centrelock 160mm discs in the garage that you are welcome to if you can cancel your order in time and dont need them to fit the 6 bolt wheels :laugh:
JhnBssll
Suffolk
Oh, forgot to mention the rotors would come with internally splined lockrings too so you wouldnt need the extra tool ;)
JhnBssll
Suffolk
simonali
:laugh:
I'm sure you could return them for a refund? I'm happy to pop these in the post if you like, let me know :okay:
Thank you very much. As I have an endless supply of money*, I'd be happy to purchase them as spares if you'd like a bit of dosh for them? Even if it's just covering your time and postage costs....
*possibly untrue. :whistle:
