Cycleops
- Accra, Ghana
Whatever happened to Yellow Saddle? Some useful posts but very prickly.
Tell us more. What is the chemical reaction which 'welds' the aluminium to the steel?Aluminium "welds" itself to the steel, it's a chemical reaction over time.
As the word "weld" is in inverted commas I guess it's alluding to galvanic corrosion?
Great to hear you're an engineer too: we can both 'appeal to authority'.
But as as you have subsequently implied, the chemical reaction is not between Al and Fe, as 'weld' implies [you said "Aluminium "welds" itself to the steel"], so maybe using 'weld' actually misinforms, rather than simplifying imho.
Al3O2 is created between the two metals, and this molecule is way larger: hence the seat post sticks.
Btw avoid the temptation to use of grease which merely keeps H2O in the interface for longer (in emulsion) and gives the galvanic corrosion longer to operate.
Periodic removal, wipe clean and reinstall is the sensible maintenance regime requiring a minute's effort every 3 months (say).
